Lumia 820
If the 1650mAH battery in the Nokia Lumia 820 isn’t cutting it for you power users, you might want this extended battery from Mugen Power. Even if you aren’t a power user, there are a handful of you out there with this device. And there’s no better way to make your battery stretch a day or two than with an extended battery.
Mugen Power made an extended battery for the Nokia Lumia 820 that takes your stock 1650mAh battery and replaces it with a 3600mAh multi-day busting battery. Yeah, that’s right. You get a battery that is twice the capacity of the one currently inside your phone.
Mugen Power
The Mugen Power 3600mAh extended battery will run you $89.50. The product ships on April 5 with free shipping internationally. So users around the globe can get more juice if they want. Unfortunately there aren’t any product shots of the battery on the Mugen Power website. We’ll ping them and see if we can get some images or just do our own hands on.
It does look like this battery will be physically bigger than the stock battery, it might also require you to use the included back plate since you specify what color you want on checkout. Again, we’ll double check and find out for you guys.
Anybody interested in doubling their battery power on their Lumia 820s?
Source: Mugen Power, Via: Yahoo News; thanks for the tip Zeroplanetz!
