Best USB Wireless Chargers for Your Office in 2022
The future of technology is wireless. Supporting this cable-free future is wireless chargers. For a device to charge/be charged wirelessly, it must be Qi-enabled or use a Qi-enabled charging case. Qi (pronounced as ''chee'') is the standard requirement for wireless energy transfer developed by The Wireless Power Consortium (WPC) to standardize wireless charging across all devices. As wireless charging gains traction, the real task lies in settling for the best wireless charger for your office. These devices come in two variations: pads and stands. We've compiled a list of the best options out there, but the Samsung Wireless Charger Duo Pad is our best pick. It comes with two charging pads, enabling you to charge two devices simultaneously.
Best Overall: Samsung Wireless Charger Duo Pad
Dual charging with fast charge 2.0
Reasons to buy
USB-C compatible
Qi-certified
Two charging stations
Fast charge 2.0
Reasons to avoid
Quite expensive
The Samsung Wireless Charger Duo Pad is the latest Samsung dual charging pad, and it allows you to power up to two devices simultaneously. The charger doesn't only support Samsung devices; it's compatible with most Qi-enabled devices, including iPhones and smartwatches.
Engineered with Fast Charge 2.0, the charger supports the maximum 7.5W charging in iOS, 10W in Android devices, and 12W with the new Galaxy 10 line. It comes with a build-in cooling fan and silent ventilation to prevent overheating. If your device is not Qi-enabled, you will have to purchase a charging case. Luckily, it's compatible with most charging cases.
Best Budget: Yootech Wireless Charger Stand
Yootech Wireless Charger Stand Qi-Certified
Quality Budget Charger
Reasons to buy
Fits the bill
Charges in both landscape and portrait modes
Fast charging
Qi-enabled and satisfied
Friendly LED light
Reasons to avoid
No adapter
Overheats
Do you want a good USB wireless charger that fits the bill without compromising on quality? The Yootech Wireless Charger Stand is an absolute bargain. It's Qi-certified and supports the latest IOS 7.5W and Android 10W fast charging. Fitted with two coils, the Yootech supports charging in both landscape and portrait modes.
Responding to notifications, watching movies, or even making calls while your phone is charging is easy since the charger is elevated at an angle. This stand works with charging cases up to 4mm thick and has an LED light that goes off 15 seconds after your phone is detected. The only downside is that the stand will stop charging once it overheats, but if you can overlook that, it's awesome for the price.
Most Versatile: Samsung Wireless Charging Convertible Stand/Pad
Convertible Stand-Pad
Reasons to buy
Convertible
Fast charging
Qi-certified
USB-C compatible
Built-in cooling fan
Reasons to avoid
Doesn't support smartwatch charging
Wireless chargers come in two variations — stands and pads — so why not enjoy both worlds? The Samsung Qi Certified Fast Charge Wireless Convertible can be used as a charging stand and pad. The stand-up angle will allow you to respond to notifications and make calls without unplugging,but you can also use it as a pad to save some desk space.
The convertible charger has a unique faux leather finish that will blend with office decor and give a firm grip on your device. It's compatible with all Qi-enabled devices and has a built-in fan to supports 9W fast charging on select devices.
Best Charging Stand: RAVPower Wireless Charging Stand
Stand-up Design
Reasons to buy
Universal Qi compatibility
USB compatible
Stand-up design
Hyper-air technology
Dual-coil charging
Reasons to avoid
Not compatible with AirPods 2
The stand-up design of The RAVPower Wireless Charging Stand is perfect for office use. The stand is elevated at an angle, giving you easy access to notifications. The charger is compatible with all Qi-enabled devices and charging cases less than 3mm thick. Plus, it supports fast charging — 7W for IOS and 10W in Android devices.
Pioneering Hyper Air technology features, the stand has temperature controls to prevent overheating, overcharging, and short circuit. It's fitted with an LED light to show charging status and an anti-slide silicone top to keep the phone firmly in place. It also comes with a USB cable and a wall power adapter.
Best Charging Pad: Anker PowerWave 7.5 Charging Pad
Ride the PowerWave
Reasons to buy
Fast charging
Supports 5mm charging cases
Effective cooling system
Universal Qi Compatibility
Reasons to avoid
Incompatible with wall chargers provided with Apple and Samsung devices
Ride the wave with the Anker PowerWave 7.5 Fast Wireless Charging pad. It's quite sleek and will occupy little space on your desk. Charging is effortless; just place your device on the pad and let the power flow. The PowerWave has set standards in wireless charging by supporting the 7.5W in Apple devices and 10W in Android.
Fast charging chargers tend to heat up and slow down, but the Anker has an efficient internal cooling fan to support fast charging from 0% to full charge. This pad is compatible with most Qi-enabled devices and can deliver a charge through heavy cases. It comes with a 3.0 AC adapter and a 6-foot Micro-USB cable. However, it charges phones in a horizontal position, accessing notifications is not as easy.
Best for Apple: Belkin Boost Up Wireless Charging Pad 7.5W
Belkin Boost Up Charging Pad
Boost Up your iPhone.
Reasons to buy
Optimized for Apple devices
Fast charging
Supports 3mm charging cases
Reasons to avoid
No 10W fast charging for Android
Belkin is a reputable company, and Apple approves it as one of its most trusted accessory manufacturers. The Belkin Boost Up Charging Pad is engineered with Apple devices in mind. It delivers 7.5W charging capacity, which is ideal for the maximum 7.5W fast charging in iPhones 8/XS/XS Max and XR. It also charges Airpods 2 at 5W. However, older iPhone models will require a compatible charging case.
Also, the pad works well with all Qi-enabled devices and charging cases. The pad has a green LED light to show correct phone alignment. It comes with a wall adapter and a USB cable.
Wireless Charging Desk Lamp: TaoTronics LED Desk Lamp Fast Wireless Charger
TaoTronics Desk Lamp Wireless Charger
Lighting & Charging Convinience.
Reasons to buy
Adjustable LED lamp
Fast charging
Fully assembled
USB port
Reasons to avoid
The plastic frame is a bit delicate
Transform your office desk into a convenient work station with the TaoTronics LED Desk Lamp Fast Wireless Charger. The TraoTronics doubles up as an LED desk lamp and a wireless charger. The lamp is fitted with a Qi-enabled wireless charging pad that delivers up to 7.5W to IOS, 10W to Android devices, and it works with charging cases.
The LED lamp is fully customizable. The lamp head is adjustable and has five color modes and seven brightness levels that you can adjust from a strong blast to warm ambiance to suit your lighting needs. Additionally, the lamp has a USB charging port. This is quite a convenient way to charge and light up your desk, especially if you work or study late at night.
Bottom line
Settling on a USB wireless chargers can be a daunting task. The Samsung Wireless Charger Duo Pad is our best pick. It checks most boxes generally acceptable for anyone looking for the perfect option for their office. With a fast-charging speed of 2.0, Qi-compatibility, and Qi-certification, the Duo Pad has it all. Plus, it has a cooling system to support fast charging and broad device compatibility. And it can juice two devices simultaneously. What more could you want out of your wireless charger?
For maximum efficiency of wireless chargers, use the right wall adapters, USB cable and do not charge the phone with credit cards or metals still in the charging case.
Grace Monene
is an avid Tech Writer. If she is not reading, she is reviewing or testing new technology. She also probably tweets way too much.
