Sponsor Content Created With HP
HP’s OmniBook Ultra 16 is its first laptop powered by NVIDIA’s RTX Spark™ SoC — and it comes with Windows
NVIDIA’s RTX Spark™ is in HP’s latest OmniBook, making it one of 2026’s most interesting laptops
Fall is officially upon us, bringing a fresh wave of cutting-edge laptops that leverage the latest and greatest in computer hardware. One of the most exciting new devices that just hit the market is HP’s new OmniBook Ultra 16, an exceptionally thin premium PC designed for AI developers and creative professionals.
There are many reasons to keep this laptop on your radar — it’s got a beautifully sharp and bright touchscreen with 100% DCI-P3 color gamut coverage, a thin and premium design for great portability, and a healthy selection of ports for peripheral connectivity — but by far, the feature that stands out the most is the system-on-a-chip (SoC) at its core: NVIDIA’s RTX Spark™.
With configurations available that give you plenty of memory and CPU power, as well as high-end AI performance and impressive GPU strength, the RTX Spark is well equipped to handle the productivity tasks you throw at it. It's been build on the NVIDIA CUDA platform, the software that accelerates the world’s AI.
Notably, it pairs NVIDIA RTX Spark with Windows, bringing NVIDIA AI, RTX graphics, and local AI capabilities to the OmniBook Ultra 16. Windows offers several special benefits compared to its peers, and together with the RTX Spark’s full capabilities and the laptop’s valuable features, it makes the OmniBook Ultra 16 a very compelling device.
Quick hits
- NVIDIA’s new RTX Spark SoC is at the heart of HP’s recently released OmniBook Ultra 16 laptop, and powers the notebook’s CPU, GPU, and AI performance that makes it an attractive option for demanding creative workloads.
- The design of the laptop itself is also very thin and premium, complete with a beautiful and bright 3K OLED HDR touchscreen, two USB-A and two USB-C ports, impressive cooling systems, a 99WHr battery rated for 17 hours of use, and more.
- The OmniBook Ultra 16 also comes with Windows as its operating system, giving you access to a gargantuan ecosystem of popular apps and tools as well as industry leading compatibility and support for PC gaming.
- The HP OmniBook Ultra 16 is available on the HP website or from Best Buy.
Leverage the full power of NVIDIA RTX Spark
The HP OmniBook Ultra 16’s strong performance stems from its RTX Spark SoC, and its presence in the laptop makes it one you should absolutely consider getting if you’re a developer or someone who regularly does creative work. The chip can be outfitted with up to 128GB of unified memory as well as an NVIDIA Grace CPU with up to 20 cores, and delivers powerful GPU performance that’s well-suited to demanding and intensive workloads.
On top of that, you also get up to 1 petaflop of FP4 AI performance from the RTX Spark, which translates to help from AI that you use for assistance with the OmniBook Ultra 16. It’s also what allows intelligent agents to run tasks, generate assets, and write code locally, reducing reliance on the cloud so your models stay local and your data stays private.
HP’s advanced design brings many benefits
NVIDIA’s RTX Spark SoC is elite, but there’s more than just its processor that makes the HP OmniBook Ultra 16 an attractive laptop. It has an impressively thin and premium design as well, with a max thickness of just 17.99mm, a starting weight of only 2.289kg, and two USB-A ports, two USB-C ports, and slots for microSD, HDMI, and audio connectivity.
These features and dimensions make the OmniBook Ultra 16 very portable and versatile, and make it easy to take it with you on the go and hook up useful accessories like mice or USB hubs. Another boon for mobile use is the large 99WHr battery under the hood, which is rated for up to a lengthy 17 hours of use on a full charge.
The notebook comes with a striking 3K OLED display with full DCI-P3 color coverage, a VESA DisplayHDR™ True Black 1000 certification, and 1,100 nits of max brightness with HDR enabled, too. With fidelity and illumination like that, you can look forward to a pleasant and clear viewing experience in many different lighting conditions.
Notably, the design also supports the performance of the RTX Spark and helps it maintain high efficiency, as its robust cooling systems — consisting of three larger heat pipes, ultra-thin dual fans, and a tower hinge and trunk design that maximize airflow and heat dissipation to help sustain performance through demanding AI and creative workloads.
Enjoy the advantages of Microsoft Windows
Finally, we come to the benefits of the OmniBook Ultra 16’s Windows operating system, which come into play for both work-related and recreational use cases.
On the productivity side of things, Windows provides access to a mammoth suite of available applications and programs, owing to the fact that most app developers build for Windows since it’s the most widely used OS for desktop and laptop PCs. That means you’ll be able to get your hands on countless different high-quality tools, giving you an incredibly diverse arsenal of resources that’ll bolster your work.
It’s also important to note that Windows is the dominant OS for gaming, with just about every game developer creating their titles with Windows in mind (but often opting to not make native versions of their games for Linux and macOS). With its powerful GPU, the HP OmniBook Ultra 16 is capable of running many games; if you’re interested in taking advantage of that when you’re not working, doing so will be easy thanks to Windows’ presence.
RTX Spark and Windows are at the heart of HP’s new OmniBook
The HP OmniBook Ultra 16 is powered by NVIDIA’s advanced RTX Spark SoC, and stands out as a compelling device to consider picking up if you’re an AI developer or creative professional. With excellent CPU, GPU, and AI power, it’s ideal for demanding workloads — and thanks to Windows, you’ll have a massive ecosystem of apps and excellent support for gaming at your fingertips, too.
Frequently asked questions
What are the key features of the HP OmniBook Ultra 16?
The HP OmniBook's key features include high-performance AI processing, a premium 3K OLED display and long battery life for mobile work.
Where can you buy the HP OmniBook Ultra 16?
You can get an HP OmniBook Ultra 16 from HP’s website or Best Buy.
How much does the HP OmniBook Ultra 16 cost?
Pricing for the HP OmniBook Ultra 16 starts at $3,199.99.
