Sponsored by HP
Ready to supercharge your AI development on the go? The HP OmniBook Ultra 16 offers the tools you need
(Image credit: HP)
Developing and coding AI is intensive and requires significant computing power, leading many to believe it can only be accomplished efficiently with a traditional, beefy desktop rig. However, that's not the case: Performant, high-end creator laptops are also well-suited for the task and add the benefit of mobility.
One such laptop is HP’s new OmniBook Ultra 16, and with its high-end specs, Windows OS, and long-lasting battery life, it’s designed to be a great laptop for AI development.
Quick hits
  • NVIDIA’s RTX Spark SoC in the HP OmniBook Ultra 16 is ideal for developing AI. It packs plenty of dependable GPU power up to 20 performant CPU cores, up to 128GB of unified memory, and up to 1 petaflop of FP4 AI performance to support local AI development and agentic workflows.
  • Notably, the laptop also uses the Windows OS, which gives you access to a colossal ecosystem of creative and professional applications. It’s also the dominant PC gaming platform, and you can take advantage of that if you like to game in your downtime.
  • On top of that, it can get up to 17 hours of battery life out of a full charge, enabling extended periods of work even when you’re away from the charger.
  • Interested in purchasing the new HP OmniBook Ultra 16? They're available from HP’s website or Best Buy.
An all-in-one chip with all the power you need
HP’s clamshell packs advanced hardware into a single all-in-one system-on-a-chip (SoC). That chip is NVIDIA’s RTX Spark, a superchip combining NVIDIA Blackwell RTX GPU, NVIDIA Grace CPU, and AI acceleration.
With GPU strength up to 6144-core NVIDIA Blackwell RTX GPU, up to a 20-core NVIDIA Grace CPU, and up to 128GB of unified memory, the RTX Spark has the resources you need for prototyping, fine-tuning, and running AI models locally.
The SoC also delivers up to 1 petaflop of FP4 AI performance; should you choose to use AI aids to help you develop your own AI, it will be able to do so very efficiently. NVIDIA CUDA™, the global standard for AI development, runs natively on RTX Spark.
Notably, the device supports handling complex and agentic AI work locally, with less reliance on the cloud. With that functionality, you can keep your models local, your data private, and your work your own, even when you’re away from the desk. That’s a huge boon, especially if you like to stay mobile — and with a rear height of just 15.73mm and a weight starting at 2.289kg, it’s a breeze to stay mobile with the OmniBook Ultra 16.
Leverage all that Windows has to offer
The OmniBook Ultra 16 features Microsoft Windows for its operating system, which gives it some special benefits — both for work and recreation.
Windows opens the door to accessing a massive ecosystem of consumer and professional apps, ranging from programs needed for specialized AI development to general productivity applications like the widely used Microsoft 365 suite. In this regard, it’s a very flexible OS.
On top of that, the HP OmniBook Ultra 16 is actually equipped to handle gaming with its robust GPU. Play the latest and greatest games with NVIDIA gaming tech, ray tracing, DLSS, and Reflex. If you like playing PC games and want to enjoy them hassle-free, having Windows is a big deal.
Cool temperatures and long-lasting performance, all day long
Lastly, HP’s design for the OmniBook Ultra 16 does a lot to combat heat. The HP OmniBook Ultra 16 sustains peak performance through demanding creative work, AI development, and agentic workflows—powered by HP's first consumer tower hinge and trunk design that maximizes airflow and heat dissipation in a remarkably thin laptop. It also utilizes three larger heat pipes and dual ultra-thin cooling fans that work together to disperse heat buildup.
In terms of battery life, the new OmniBook is rated for up to 17 hours of usage time on a full charge; this gives you extended periods of time to work on your projects even when you’re not near the charger, which is always a plus.
Additionally, the OmniBook Ultra 16 supports fast charging from low battery, so even if you do run out of power, a short stint on the charger is all the laptop needs to get up and running again. Just 30 minutes of charging should get you back up to 50% capacity.
Empower your AI development with HP’s new OmniBook
With the advanced hardware specs of NVIDIA’s RTX Spark SoC, the Windows OS’s incredible app ecosystem, excellent versatility and up to 17 hours of battery life, HP’s OmniBook Ultra 16 has the resources to supercharge your AI development — and it packs it all into a thin and premium chassis, complete with a sweet selection of ports and a striking 3K OLED touchscreen. If you’re after a great device for building AI and you want to stay mobile while you’re doing it, look no further.
Frequently asked questions
What are the key features of the HP OmniBook Ultra 16?
The HP OmniBook key features include high-performance AI processing, a premium 3K OLED display and long battery life for mobile work.
Where can you buy the HP OmniBook Ultra 16?
You can get an HP OmniBook Ultra 16 from HP’s website or Best Buy.
Who is the HP OmniBook Ultra 16 good for?
It's a great fit for a variety of different creators, but it's particularly helpful to AI developers with additional features.
Brendan Lowry
Contributor, Gaming
