HP introduces a 4K NEO:LED monitor — a new display technology that brings IPS closer to OLED quality
HP Series 7 Pro 4K Monitor showing a colorful image of a woman holding a brush.
HP is going all out for CES 2026, with a wide range of products to show off for the new year.
Among the devices announced is the latest iteration of the HP Series 7 Pro 4K Monitor, which has grabbed our attention here at Windows Central thanks to its many useful features, impressive motion clarity, and notable visual quality — all of which are due to the new NEO:LED technology it uses in conjunction with Black IPS.
Take a look at this 31.5-inch monitor's specs yourself:
Swipe to scroll horizontally
HP Series 7 Pro 4K (732xk) Monitor specs
Display type
31.5 inches, 4K UHD IPS Black; NEO: LED anti-glare
Aspect ratio
16:9
Refresh rate / Response time
120Hz / 5ms
Brightness / Contrast
450 nits / 2700:1
Flicker-free
Yes
Color range
99.4% of Adobe RGB, 99.4% of P3, 100% of sRGB
Bezel
4-sided borderless with micro-edge bezel design
Adjustment
Tilt: -5 to +20 degrees | Swivel: +45 degrees | Pivot: +90 degrees | Height: 150mm
Features
Single Power On, Smart KVM, HP Eye Ease, 100x100m VESA mounting
Ports
1 x HDMI 2.1, 1x DP 1.4, 1x DP 1.4-out, 1x Thunderbolt 4 with USB Type-C 40Gbps signaling rate (up to 140 W USB Power Delivery, DisplayPort 1.4), 1x Thunderbolt 4 Out (15W) for Daisy chain, 1x USB Type-C 10Gbps signaling rate (Up to 140W USB Power Delivery, Alt Mode DisplayPort 1.4), 1x USB Type-C 10Gbps signaling rate (15 W charging), 5x USB Type-A 10Gbps signaling rate (1 charging), 1x RJ-45 (10/100/1000/2500 Mbps)
What's in the box
Monitor, Thunderbolt cable, HDMI cable; Warranty card, AC power cable, Quick Setup Poster, 1 USB Type-C to Type-A cable, DisplayPort 1.4 cable, Base stand, Thunderbolt 4 cable, VESA mount adapter
If you haven't heard of NEO:LED displays before, that's because this is a very new technology developed by LG, which produces crisper details, deeper darks, and more vibrant colors than is typically seen in IPS panels.
MORE CES 2026
A badge that says "Windows Central CES 2026" on top of a blurred convention center background.
(Image credit: Windows Central (Edited with Gemini))
• Start: Tuesday, January 6, 2026
• End: Friday, January 9, 2026
• Where: Las Vegas, Nevada
• More info: CES 2026
According to HP, the 31.5-inch Series 7 4K Monitor is capable of reaching up to a 120Hz refresh rate and 5ms response time while producing up to 99.4% of Adobe RGB, 99.4% of P3, 100% of sRGB, which is well within the color range realm of an OLED display. Using IPS Black technology, it even produces 2700:1 contrast. Impressive indeed for an IPS panel.
RELATED: IPS LCD vs OLED vs NEO:LED vs tandem OLED vs QD-OLED vs QLED vs AMOLED vs Mini LED: Which is the best display?
HP Eye Ease allows the monitor to be put in low blue light modes to reduce eye strain during computer sessions. As with most HP displays, this monitor can be managed using HP Display Center software.
To keep focus on the beautiful screen and the visuals it displays, this monitor offers a borderless design with micro-edge bezels. It's also anti-glare, so pesky reflections don't distract from the main event.
But the HP Series 7 Pro 4K is not just beautiful to look at; it also provides several convenient features that make it perfect for creative projects and artists. Namely, it offers a Smart KVM, allowing owners to use the same keyboard and mouse between two connected devices.
Additionally, it offers a healthy range of ports, complete with RJ45 for a wired internet connection, Thunderbolt 4 Type-C for connecting those aforementioned devices, and USB-A ports for various accessories. Meanwhile, this display also has Single Power On, which is a handy feature that, as the name implies, wakes your PC when you power on the monitor.
Getting the monitor into a perfect viewing position should be easy enough, given that it can be adjusted vertically, tilted, swiveled, and pivoted until the display is in the best location for your setup. And if you'd rather mount the monitor, it has a detachable base and supports 100x100m VESA mounting.
The 31.5-inch HP Series 7 Pro 4K Monitor (2026) is expected to be available in March on the HP website. Pricing has not been revealed yet, but will be disclosed closer to that launch period.
A pink banner that says "What do you think?" and shows a dial pointing to a mid-range hue on a gradient.
What do you think about the HP Series 7 4K Pro Monitor? Are you interested in NEO:LED display technology? Tell us about it in the comments.
Rebecca Spear
Gaming and News Editor
Self-professed gaming geek Rebecca Spear is one of Windows Central's editors and reviewers with a focus on gaming handhelds, mini PCs, PC gaming, and laptops. When she isn't checking out the latest games on Xbox Game Pass, PC, ROG Ally, or Steam Deck; she can be found digital drawing with a Wacom tablet. She's written thousands of articles with everything from editorials, reviews, previews, features, previews, and hardware reviews over the last few years. If you need information about anything gaming-related, her articles can help you out. She also loves testing game accessories and any new tech on the market. You can follow her @rrspear on X (formerly Twitter).
