I switched to HP's $6,000 Omen Max 45L pre-built gaming PC for two weeks, and the price isn't what's giving me second thoughts
I love the PC's performance and cooling, but at the asking price, HP could be paying more attention to small details.
A modern HP Omen Max 45L gaming PC case with illuminated cooling fans and colorful internal components, placed beside a bookshelf and indoor plants.
(Image credit: © Future)
Windows Central Verdict
HP's Omen Max 45L is a flagship pre-built desktop gaming PC with a few stellar tricks up its sleeve, but overall, I'd rather spend big money on a boutique build with better cable management, a higher build quality, and similar pricing.
Reasons to buy
    Easy toolless access on all sides
    Cryo Chamber cooling is ingenious
    Uses standard parts for easier future upgrades
    Monstrous gaming and creative power available
    Quality PSU has an auto-cleaning fan setting
    Quiet and cool performance
Reasons to avoid
    Cable management could be better
    Comes with a lot of bloatware
    Build quality lacking in some areas
    Why not make use of space and use an ATX board?
    Port selection could be better
HP announced its new Omen Max 45L desktop gaming PC in 2025, and it arrived with several upgrades over previous models.
I'm talking about an upgraded cooling system built on the back of HP's unique "Cryo Chamber." About a new modular power supply with an auto-cleaning fan. About new in-depth overclocking abilities.
The Omen Max 45L recently landed in my office, and I've been using it for a couple of weeks to see what it's all about. Does it make a strong case for itself compared to a DIY build? Does it have enough premium features to warrant a premium price? Here's what you need to know.
Why you can trust me
Cale Hunt
Cale Hunt
I've been tinkering and building PCs for decades, and I've had more than 10 years of experience testing and reviewing pre-built desktop gaming rigs here at Windows Central. I know what's good and what's not, and you can trust my advice when shopping for a new system.
Disclaimer
HP sent Windows Central a review unit on loan for testing. It had no input, nor saw the contents of this review, prior to publication.
How much does the HP Omen Max 45L cost?
The RTX 5080 is the second-most powerful GPU option available in the HP Omen Max 45L. (Image credit: Future)
HP's Omen Max 45L does not come cheap as a direct result of inflated component costs and the general high-end nature of the system.
Looking at HP.com at the time of writing, prices start at $3,489.99 for a model with an AMD Ryzen 7 9700X CPU, NVIDIA RTX 5070 GPU, 32GB of Kingston Fury DDR5-6000 RAM, and a 1TB M.2 PCIe 4.0 NVMe SSD.
Prices climb all the way to $6,499.99 for a model with an AMD Ryzen 9 990X3D CPU, NVIDIA RTX 5090 GPU, 4TB of storage, and 64GB of DDR5 RAM.
The specific unit I'm reviewing costs closer to $5,959.99 before any discounts. At the time of writing, it's $800 off the regular price, bringing it down to $5,159.99. Here's a closer look at the specs that make up the PC I'm testing.
Swipe to scroll horizontally
Row 0 - Cell 0
HP Omen Max 45L
CPU
AMD Ryzen 9 9950X3D
GPU
Custom NVIDIA RTX 5080
RAM
64GB DDR5-6000 Kingston Fury Beast RGB
Storage
2TB M.2 PCIe 4.0 NVMe, Samsung PM9A1
Motherboard
Custom, Micro-ATX, AMD X870
PSU
1200W, Cybenetics Platinum, modular, ATX 3.1
Wireless
Wi-Fi 6E or Wi-Fi 7, Bluetooth 5.3 or 5.4
Dimensions
8.03 x 18.15 x 21.85 inches (20.3cm x 46.1cm x 55.49cm)
Weight
49.82 pounds (22.59kg)
Warranty
1 year, HP Care Pack options available
I put together a mock build on PCPartPicker to compare pricing. With the CPU, GPU, RAM, storage, PSU, X870 motherboard, Windows 11, and Lian Li O11 case, you're looking at roughly $4,616. Add some extra ARGB case fans in there, and you might hit $4,800 to $5,000.
Without a discount, HP is charging a lot more for the Omen Max 45L compared to building your own. If you are interested in this PC, I definitely recommend waiting for a deep discount.
Is the HP Omen Max 45L assembled properly with good cable management?
Cable management and build quality aren't perfect in the Omen Max 45L. (Image credit: Future)
I've been on a run of good luck lately regarding pre-built PCs I tested and reviewed, and I had high hopes for the Omen Max 45L's build quality and cable management.
In the former case, it's a bit of a mixed bag. The PC has a sturdy separate top compartment that can be used to lug around the 50-pound system, quick-release side and front panels, and a pull-off top panel hiding the AiO radiator.
It's easy to get inside the PC without any tools, and I appreciate that there's a removable dust screen for the three front intake fans. I live with two cats and ... you get the idea. I've been using the PC for a couple of weeks, and there was minimal dust to blow out when it came time for photos.
The massive RTX 5080 GPU is held in place with an additional bracket — also removing the need for any bothersome foam packing en route — and I had to make no adjustments out of the box. The PC turned on and booted up as soon as I hit the power button.
There are a couple of areas where the build quality could be better. I noticed immediately that the CPU pump header isn't mounted squarely on the chip. The front panel of the case seems to stick on one side. And the rear side panel doesn't quite match up flush with the rest of the tower unless I really take my time lining it up.
Cable management leaves a lot to be desired
The Omen Max 45L's cable management leaves a lot to be desired. (Image credit: Future)
Cable management in the HP Omen Max 45L isn't great. It feels like it was a rushed job, leaving stray cables and extra length on the visible side. Not only does this make for a messy appearance, but it can also interfere with internal air cooling.
Around the back, behind the all-metal panel, things aren't much better. Compared to, say, Maingear's MG-1 MK.II or Acer's Nitro 65, the Omen Max 45L's (normally) hidden cabling is spaghetti.
A look at some of the visible cabling inside the Omen Max 45L. (Image credit: Future)
There's a snarl of cables pinched between the panel and motherboard backing, and another snarl sitting in front of the modular PSU. One thing I can appreciate is that the correct SATA cables are sitting idle in front of the dual (empty) HDD bay for easier connectivity.
How is port selection on the HP Omen Max 45L?
The front of the case hosts four ports and an LED power button. There are two USB-A at 5Gbps each, one USB-C at 10Gbps, and one 3.5mm audio combo jack. Not too bad in terms of convenience for ports often used.
Around back, on the custom HP micro-ATX motherboard, you'll find four USB-A 2.0 ports (with speeds measured in Mbps) as well as two more USB-A at 5Gbps. Two additional USB-C at 10Gbps round out USB connectivity.
This is a fairly austere port setup, leaving a lot of space on the board's I/O blank.
HP has a 2.5Gb Ethernet port for wired connectivity, as well as dedicated jacks for line in, line out, and microphone. This is a fairly austere port setup, leaving a lot of space on the board's I/O blank. At least there's an easy CMOS reset button available.
As for the GPU, ports depend on the card you get. The RTX 5080 here has one HDMI 2.1b and three DisplayPort 2.1b.
How does the HP Omen Max 45L's cooling set itself apart from other PCs?
The Cryo Chamber adds an air-gapped section for the AiO's radiator. (Image credit: Future)
The Omen Max 45L's most prominent feature is its dedicated Cryo Chamber that hosts the AiO CPU cooler's radiator separately from the rest of the PC. The air-gapped setup means that only ambient air is cooling the fins, and the hot air forced out the other side by the fans doesn't enter back into the PC.
It's an admittedly ingenious setup that makes a difference, especially when you're working with flagship GPUs that produce quite a bit of heat that's spilled directly into the main portion of the case. It does, however, add quite a bit of bulk to the case. If you're short on space already, this probably isn't the PC for you.
The Omen Max 45L uses mostly standard parts
HP uses custom parts in the Omen Max 45L, but they're sized appropriately for easy future upgrades. (Image credit: Future)
A big issue a lot of people have with big-brand pre-built PCs is their insistence on using proprietary hardware inside. I'm talking about parts that can't be easily replaced because they're some weird size or shape.
That's not the case here. Well, not exactly. The motherboard is a custom micro-ATX HP 8E55 using AMD's X870 chipset. It's a standard size that makes for easy replacement, and the case also fits up to a full-size ATX board.
I'm not sure why HP didn't just go for the full-size board in the first place. The massive GPU blocks off a lot of the board, and you'll absolutely be pulling the card out of the case if you have to do anything that involves the secondary SSD or the M.2 Wi-Fi card.
The RTX 5080 is also a custom HP job with a snazzy Omen-styled casing. It performs just as well as any other 5080 out there made by a known brand.
I tested it using 3DMark's Speed Way and Steel Nomad tests and came back with these scores of 8,996 and 8,628, respectively.
The RTX 5080 in the Omen Max 45L performs exactly as expected. (Image credit: Future)
There were no surprises from the AMD Ryzen 9 9950X3D, either; it performed as expected in baseline benchmark tests. If you're buying this PC strictly for gaming, I'd recommend sticking with the Ryzen 7 9800X3D. It costs $330 less and will deliver incredible gaming performance.
The Samsung SSD isn't the fastest we've tested, but it gets the job done with 6,626 MB/s read and 4,993 MB/s write speeds. Check out these graphs for a comparison to other hardware we've recently tested.
The PSU is actually one of the PC's strong points, which goes against a lot of other pre-built systems. It's a 1200W Platinum-grade option with a Cybenetics Platinum rating. It's fully modular for easy tweaking, it's quiet, and it has a custom reverse fan cleaning tool to spin the dust out of the hardware.
Even the separated AiO cooler can be replaced should the stock HP option that ships with the PC not be up to snuff for your needs.
Does the HP Omen Max 45L have good airflow?
There's almost no difference in temperate with the front glass panel removed/in place. (Image credit: Future)
To check airflow and temperatures, I ran a lengthy 3DMark Speed Way stress test. With all panels in place, including the front glass panel, the CPU hit 46 degrees Celsius, and the GPU hit 75 degrees.
With the front glass panel removed, GPU temperatures fell to about 74 degrees Celsius. The CPU, with separated cooling, saw no change. That's a minor difference, and you should have no problems keeping the PC cool as intended.
It's worth noting that the PC runs very quietly. The most noise I could get out of it was during the stress tests, and it peaked at just 47 decibels. That's quieter than most other pre-built PCs I've tested, and you'll hardly notice it's running even under load.
Does the Omen Max 45L come with useful custom software?
The main software to control this PC is HP's Omen Gaming Hub. It serves ads while open (annoying), but it does a decent job of controlling the PC.
The ARGB in the PC seems to have some issues, and I suspect it has to do with HP's firmware. It'll turn off randomly and not turn back on until the PC restarts, or it will reset on its own while using the PC.
HP includes a lot of software I deem unnecessary, including McAfee antivirus, Adobe offers, and Booking.com. It's classic bloatware. That's without mentioning the seven different HP apps that come preinstalled.
It can all be removed, but it's still an annoyance on a PC this expensive, especially when competitors are shipping clean installs of Windows 11.
Should you buy the HP Omen Max 45L?
You're going to need a fair amount of space in your gaming area to fit the Omen Max 45L. (Image credit: Future)
You should buy this if ...
✅ You want a unique and powerful desktop PC for gaming or creative work.
✅ You'd rather not save some money with a DIY build.
❌ You're looking for the best value possible in a pre-built gaming PC.
❌ You want the absolute best cable management and build quality.
There's no question that the HP Omen Max 45L delivers on top-tier performance and cooling. Unfortunately, its assembly and cable management don't feel like they match the high price.
Worse, the PC comes with quite a bit of bloatware, and there are what I suspect are firmware issues that plague the built-in RGB lighting.
The pre-built gaming PC market has come a long way in recent years, and the Omen Max 45L ultimately feels like it's stuck in the past. It won't disappoint those who need a ton of power, but there are plenty of alternatives out there that will deliver a superior product at a similar price.
TOPICS
Cale Hunt
Contributor
