The Anker Soundcore Liberty 2 Pro true wireless earbuds are down to $119.99 with the $30 off on-page coupon at Amazon. We have seen the black version of these earbuds drop to around $110, but it looks like those earbuds are no longer available. And the white ones have never gone this low before. The earbuds normally sell for $150 and have gone for even more than that recently.
Sounds good
Anker Soundcore Liberty 2 Pro true wireless earbuds white
These earbuds include USB-C charging and are Qi-compatible for wireless charging. Have 8 hours of playtime. Earbuds can be used independently. Built-in mic has noise reduction. Case can recharge earbuds 3 times before needing to be plugged in.
$119.99 $150.00 $30 off
With coupon: Clip the on-page coupon
These earbuds have eight hours of playtime per earbud, and you can use the earbuds independently to extend that use. The charging case they come with adds another three full recharges before you ever need to plug into a wire to juice back up. With a quick charge of just 10 minutes inside the case you can get an extra two hours of playtime. Plus, the charging case can be recharged via USB-C or a Qi-compatible wireless charging pad, giving you plenty of options for keeping these batteries topped off. RAVPower has a wireless charging pad on sale for just $12.24 today you can use with these earbuds.
Save big with VPN deals from ExpressVPN, PureVPN, Surfshark & more
The Astria coaxial acoustic architecture helps eliminate interference and produces harmonized treble and bass for fantastic sound. The 11mm dynamic drivers support the immersive audio and create an expansive soundstage. The HearID technology inside the earbuds helps analyze your hearing profile and creates tailor-made sound just for you so anyone using these earbuds gets the perfect listening experience.
The earbuds also have microphones built in so you can use them to answer calls. The four mics combined with cVc 8.0 noise reduction technology helps ensure your voice stays crystal clear and no background noise interupts you.
Read more about the Soundcore Liberty 2 Pro in our review that gave them 4.5 stars out of 5 and a Recommended badge. Daniel Bader said, "The Liberty 2 Pro are an incredible pair of true wireless headphones that are easily worth their steep $150 asking price." Good thing they're cheaper now!
