Best Black Friday PC parts deals
You are now subscribed
Your newsletter sign-up was successful
Join the club
Get full access to premium articles, exclusive features and a growing list of member rewards.
Today's Black Friday PC parts deals are an excellent opportunity to upgrade your PC for less. For sure, finding the best graphics card on sale, or even in stock will be tough, but most other elements of building or improving your PC are much cheaper today. If you are tempting to dive into something ready-made tohugh, we have a guide to the best Black Friday pre-built gaming PC deals.
Whether you're in the market for a new motherboard, some storage, or everything in between, we've rounded up some killer deals right here for you to consider. As always, it's best to decide on what to upgrade inside your PC and what will be the best upgrade to go for.
Choosing the right PC components doesn't just depend on the price. For instance, you'll need to make sure a discounted motherboard will work with your CPU, likewise with a CPU deal to your existing motherboard.
Where to find the best Black Friday PC part deals
Black Friday will likely see plenty of deals on PC parts, from graphics cards to processors. If the deals haven't started already, we'll be keeping tabs on any new ones as they pop up right here. But where can you go and find some deals? Amazon is one of the more popular destinations, but you must be wary of third-party listings and inflated prices.
- Amazon: Big price crashes on SSDs, CPU, cooling and much more
- Newegg: Specialist is roicking cheap RAM, motherboards and much more
- Best Buy: Often overlooked in this market but actually packed with deals
Best Black Friday PC part deals: Processors
The central processing unit (or CPU for short) is the brain of the PC and handles all the tasks that need processing. It's what determines whether you'll be able to run software and games with little issue. The more powerful (and expensive) the CPU, the fewer restrictions will be in place. It's best to spend as much as you can here to save upgrading sooner rather than later.
The AMD Ryzen 7 5700G is a special CPU since it contains an integrated GPU. This doesn't sound much for those who used Intel CPUs before, but this is no ordinary GPU. It's Radeon graphics that allow this 8-core, 16-thread processor to easily handle modern games on its own with impressive results. If you're buying from Newegg, be sure to use promo code BCMAY22642!
Best Black Friday PC part deals: RAM
RAM is what's used by the system to store data for quicker access. Even the fastest SSDs aren't as quick as RAM. 8GB is recommended as the minimum for Windows and Linux, though we'd recommend 16GB if you plan to play games. Your CPU will have the maximum speed it can support. Modern CPUs may work with 3200MHz DDR4 or 4800MHz DDR5 modules, so double-check before buying.
Best Black Friday PC part deals: Storage
You're going to need a place to store not only the OS but also software and games. We'd recommend using the fastest SSD your motherboard supports. If it's a new motherboard, you'll likely be able to install an NVMe PCIe SSD with speeds of up to 7,000MB/s. Say farewell to loading screens.
Seagate FireCuda 530 PCIe 4.0 SSD | Up to $115 off
The FireCuda 530 SSD offers read speeds up to 7,300MB/s thanks to PCIe 4.0 technology. If your PC supports it, this is a great upgrade for gamers and power users who can't stand lengthy load times.
Crucial's reliable P2 internal M.2 SSDs are all on sale for Black Friday, with the best deal coming in the form of the 2TB model. However, all sizes from 250GB and up are on sale.
The SK hynix Gold P31 is available in 500GB, 1TB, and 2TB sizes. Each is available with an extra 15% off at Amazon when you check the coupon code on the product page. You'll save the most money on the 2TB model, though 1TB and 500GB are also looking quite attractive.
Crucial X6 external SSD | Up to $50 off
Crucial's X6 external SSD is capable of read speeds up to 540MB/s, but it's small enough to slip into your pocket. Save on 500GB and 1TB models at Amazon.
Best Black Friday PC part deals: Cases
There's no point in spending all the money in the world on fancy hardware if you don't have a PC case in which to install it all. This is where our shortlist of chassis comes into play. Mid-tower size is best suited for most PC builds. ITX cases require Mini-TIX motherboards, which are usually more expensive, while full-tower covers your large behemoth cases.
Hyte Revolt 3 ITX case (white) | Up to $50 off
The Hyte Revolt 3 ITX case in a white finish is available for as low as $100 as long as you don't mind adding your own PSU. If you'd rather include a modular 700W Gold SFX PSU, the price goes up to $200, with a $50 savings.
Hyte Revolt 3 ITX case (black) | Up to $50 off
The Hyte Revolt 3 ITX case is also available in a black finish. You can get a case without an included PSU for $100 (which is $30 off), or you can get one with an included modular 700W Gold SFX PSU for $200. That's a better deal, saving you $50.
Best Black Friday PC part deals: Motherboards
The motherboard is the heart of a PC, acting as the bridge between all your installed hardware. This is one of the most important parts of the PC, and it's easy to mess things up if you choose the wrong one. If you already have a CPU at the ready, choose a motherboard that supports it. If not, go with whichever supports the CPU you plan on purchasing.
Best Black Friday PC part deals: Cooling
You're going to need some serious cooling for more powerful PC components, but thankfully Black Friday also discounts CPU coolers, fans for cases, and more.
Best Black Friday PC part deals: Power supplies
The power supply unit (or PSU for short) is the most important part of the PC. It's what delivers stable power to all your components, converting alternating current (AC) to regulated direct current (DC) in the process. If you buy a cheap PSU from an unknown brand, you run the risk of damaging your components.
When do the Black Friday PC parts deals begin?
Deals can be expected to start on Monday, Nov. 22, running through the week in the run-up to Black Friday. We'll see the full brunt of promotions on Nov. 26, but retailers are attempting to get ahead by guaranteeing prices right now.
Don't be shy if a product you've been after for some time is now available for less as the retailer may guarantee the price throughout Black Friday, so you won't feel left out. Just watch out for the guarantee messages to be sure you're not going to see a lower price closer to Black Friday.
Best Black Friday PC part deals: Graphics cards
The GPU is the most important component of PC gaming. Without one, you're left with whatever comes with the CPU — and not every CPU comes with integrated graphics processing. Like the CPU, spend what you can here to make sure you have the best available to your budget. You're still going to have issues finding GPUs right now as demand far outpaces demand, but we'll be sure to post any deals we find right here.
HP Omen 30L prebuilt gaming PC | Extra 10% off
Really want to save on a graphics card this year? Upgrade to the one you want in a prebuilt desktop like this where they don't overcharge you for it. It's the best way to avoid scalpers and over-priced eBay listings. Plus, with HP if you spend at least $1,000 you can use code WINTER10 to save 10%.
