Charging your devices efficiently could mean the difference between leaving home at 50% and having a full battery. If you're looking to power up your phone, tablet, and other devices faster, you'll want to pick up a USB-C charger with Power Delivery. This dual-port RAMPOW 36W USB-C wall charger, for example, falls to just $17.54 when you use promo code H7RKM2HS during checkout at Amazon. That saves you 35% off its current price of $27 there.
Nearly $10 off
RAMPOW 36W 2-Port USB-C Wall Charger
Power up quickly with this 36W USB-C wall charger which is equipped with a USB-C PD port and a USB QC 3.0 port so you can charge two devices simultaneously. The following code saves you 35% off at checkout while supplies last.
$17.54 $26.99 $9 off
Rampow's 36W 2-port charger includes a USB-A port with Quick Charge 3.0 and a USB-C port with Power Delivery 3.0. The power output for the USB-C port, when used alone, is 30W and each port can output 18W when used at the same time. The combination of Quick Charge and Power Delivery gives you plenty of juice to charge your devices up to four times faster than conventional charging. The charger works with basically any USB-powered device and is especially good for anything that is USB-C only like new MacBook models or modern Android phones.
You can take this charger with you anywhere. Let it be the new companion to your smartphone or laptop. Keep it in your backpack or purse or take it while you commute. Thanks to its lightweight design and the fact that it has foldable plugs, you can travel with it pretty easily.
There are built-in safeguards that will protect the charger and the devices connected to it from anything bad. That includes overheating, over-voltage, and short-circuits. It's also backed by a lifetime warranty in case of any issues.
Shipping at Amazon is free on orders totaling $25 or more, though you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to all of Prime's perks such as the Prime Video streaming service, exclusive members-only discounts, and more.
Everything you need to know about AMD Radeon RX 6000 GPUs
AMD has unveiled its new lineup of Radeon RX 6000-series graphics cards, with three new pieces of hardware to look forward to. Here's what you need to know.
AMD will announce its next RX 6000-series GPU today; here's how to watch
AMD will hold a hardware event today to announce its next Radeon RX 6000-series GPU. The GPU is expected to compete with some of the best graphics cards on the market and be based on AMD's RDNA 2.
Here's why you might want human presence detection in your next laptop
Human presence detection is the next big feature coming to modern Windows laptops. Here's what you need to know about the tech that's making your digital companion more secure and easier to use.
Rechargeable mice are eco-friendly and convenient. These are our favorites
A rechargeable mouse will take the worry out of having your wireless mouse die at the most inopportune moment; the moment you run out of fresh batteries. Charge up your mouse and get to work.
