Do you know the great thing about phones with wireless charging? They charge. Wirelessly. I know, I know. It's revelation. You just put your phone down and the next time you pick it up, it has more power! Crazy, right? Be a part of that magic with RAVPower's HyperAir Qi fast wireless charging pad on sale for $13.99 with code ZMRLDCDD at Amazon. That's 50% off the regular price and the best deal we've seen for this particular version.
Speed is the Key
RAVPower HyperAir 10W Qi fast wireless charging pad
Detects Android or iOS and delivers fastest speed possible. Has LED indicator. Safety precautions include 15% faster heat dispersion, triple temp control, and more. Clip the on-page coupon and use the following code at checkout to save.
$10.99 $28.00 $17 off
With coupon: ZMRLDCDD
HyperAir is RAVPower's own tech that speeds up how fast the pad can detect what sort of device is placed on it and start providing the fastest possible charge. It uses the same frequency as the iPhone so it can immediately start charging your iPhone, giving you the juice you need just that much faster. Plus, since it also works with Android phones there won't be a noticable difference switching to those devices, either. It does all this while also using triple temperature controls for 15% faster heat dispersion, keeping your new charger and your mobile device safe from overheating.
Shop Cyber Monday deals at: Amazon | Walmart | Best Buy | Microsoft | Dell
Other safety features include protection from overcharging, overcurrent, short circuiting, and more. The pad provides up to 10W for Android phones like the Samsung Galaxy S9 and 7.5W for iPhones. It has an LED light that flickers green when your phone is charging and turns solid when fully charged.
You can keep your case on your phone as long as it's not too thick. The pad will detect phones through 3mm of case. It won't work if there is any metal or magnetic objects between the phone and the pad, though, which may be a problem if you use certain car mounts with your phone that require these things. You also need to make sure you use the included adapter or the LED will flash red and the charger will stop working.
