Over at Dell you can get the U2415 UltraSharp 24-inch 1200p LED monitor on sale for $249.99 with a $100 Dell gift card. You can actually find this monitor going for a slightly lower price elsewhere like $229.94 on Amazon. However, that price doesn't include the $100 gift card. So if you plan on upgrading your setup with some speakers or something like that, Dell's deal is worth a lot more.
Extra Savings
Dell U2415 UltraSharp 24-inch 1200p LED monitor
The screen has a 1920 x 1200 pixel resolution, a 60 Hz refresh rate, and a 6 ms response time. It has 178-degree viewing angles, anti-glare features, Dell Display Manager, and more. The connectivity options include HDMI, mini DP, DP, and USB 3.0.
$250 + $100 gift card
The UltraSharp monitor has a 1920 x 1200 pixel resolution, a 60 Hz refresh rate, and a 6 ms response time. It's an IPS panel that has 178-degree viewing angles so you can get a good look at whatever's on the screen from any vantage point. It includes enhanced power management features like PowerNap and Dell Display Manager to dim the monitor or put it to sleep when not in use.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
The display has a lot more connectivity options than most monitors. It has two HDMI ports, one mini DisplayPort, one regular DIsplayPort, one DisplayPort out, one audio line out to connect to speakers, one upstream USB 3.0 port, and five downstream USB 3.0 ports, including one with battery charging.
There is a height-adjustable stand that can tilt, pivot, and swivel. You can also use the standard 100mm VESA mount to put it on the wall or an arm.
Users give this screen 4.3 stars out of 5 based on 1,103 reviews.
