NZXT is getting into the Black Friday spirit by offering 10% off its collection of PC components, as well as its BLD prebuild PC service. If you're shopping around for a new motherboard, AIO cooler, or a new PC altogether, you may want to check out this promotion to see if anything takes your fancy.
We've reviewed countless NZXT products here and gave the revamped NZXT H510 Flow case and NZXT N7 B550 motherboard top marks.
NZXT H510 Flow
NZXT BLD & PC parts | 10% off
Build the PC of your dreams (or have NZXT build it for you) with 10% off NZXT's entire collection of parts and its BLD build service.
Building a PC in 2021 has been a strange process thanks to the lack of available stock, inflated prices of electronics, and the comeback of Intel with the launch of 12th Gen processors. Building your own PC doesn't have to be a daunting task, but if you really don't feel comfortable, NZXT will happily install all the parts, test the system, and ship it out to you at a 10% discount for Black Friday.
The NZXT BLD service uses the company's excellent range of PC cases and other parts to create something truly special for PC gamers, starting with the Foundation PC. Should you feel comfortable enough to go it alone, you can save the same 10% across the entire range of NZXT parts, including motherboards, power supplies, and AIOs. We've rounded up a few below:
NZXT Kraken Z73
RGB cooling: Kraken Z73 RGB
The NZXT Kraken Z73 is an excellent AIO CPU cooler. Even if you plan on going with an Intel Core i9 or AMD Ryzen 9 processor, you won't have any issue overclocking and enjoying your favorite PC games. Now available in white!
$310 at NZXT
NZXT H510 Flow
Maximum airflow: NZXT H510 Flow
The NZXT H510 Flow is the latest version of NZXT's popular mid-tower case. It's the same H510 that we reviewed favorably, but it comes with a mesh front panel that allows for considerably more air to be pulled through to cool what's installed.
$110 at NZXT
NZXT N7 B550
Mother of all boards: NZXT N7 B550
There's so much to appreciate with the NZXT N7 B550 motherboard. It's one of the best B550 chipset AMD motherboards around, rocking plenty of expansion, numerous I/O headers, and excellent cooling support. It also allows for NZXT components and accessories to connect directly without a controller hub.
$255 at NZXT
NZXT C PSU
Clean power: NZXT C850 Gold
The C series of power supplies are great for supplying clean and reliable power to all your components. We reviewed the NZXT C650 and gave it high marks for being a Seasonic build, coming with a 10-year warranty, and having a fully modular design.
$145 at NZXT
