Keeping your workspace tidy is a never-ending task, which is why you should stay prepared for the job with something like the QICENT Cable Management Organizer. It can hide away your cable eyesores and more to keep you focused, and though it normally sells for $19.99 at Amazon, today you can grab one for just $11.99 when you enter promo code MNL8IDN9 during checkout. It's only dropped that low without a code once before.
Desk essentials
This cable management storage box lets you hide away various devices, cables, and power strips to help achieve a tidier look. If you hurry, entering the code below can snag you one of its best prices in history. It won't last long though.
$11.99 $19.99 $8 off
With coupon: MNL8IDN9
This box lets you store power strips, adapters, and USB hubs inside to keep your desk from looking like a madhouse, while designed with several holes where you can string cables through for access. It's made of high-strength ABS material and could even be a place to store devices like your phone. Plus, thanks to its design which dissipates heat, you won't have to worry about it getting hot while devices are stored inside either.
The next product that might do wonders for keeping your desk looking a bit nicer is this discounted Aukey XXL mouse pad. Using code 55T42OCA during checkout drops its price to $12.
