Upgrading your TV doesn't have to cost a fortune. Take this LG 65-inch 4K UHD HDR Smart TV, for example. It's discounted to only $529.99 at Dell for a limited time saving you $70 off its list price and you also get a free $100 Dell gift card thrown in. Shipping is free. You can get the same price at Walmart, though there's no added extra there.
Screen savings
LG 65-inch LED 4K Smart TV (65UM6900PUA)
This gorgeous 4K UHD HDR smart TV features LG'S ThinQ Ai tech and is compatible with Google Home and Amazon Alexa.
$529.99 $599.99 $70 off
The TV — model number 65UM6900PUA — has a 3840 x 2160 resolution with support for HDR10. With LG's ThinQ AI tech, you'll be able to hook up the TV to your smart home system via Google Home or Amazon Alexa, and the webOS smart platform gives you access to all your favorite streaming apps. Connectivity options include three HDMI ports, two USB, one optical audio, and more.
Dell's gift cards are very specific. You'll be emailed the code within 20 days of your purchase, and you have 90 days to use it at Dell.com before it expires. You can try upgrading your TV with a soundbar or speakers, or spend on something else entirely like an Xbox One S.
