GameSir G7 Pro wireless controller review: STILL wired-only with Xbox, but I love it anyway
The GameSir G7 Pro is a LOT of controller for $80, but it's still missing the one feature I actually want... for now?
Image of the GameSir G7 Pro wireless controller.
You got so close to nailing it, GameSir. Just a little farther. (Image credit: © Windows Central | Zachary Boddy)
Windows Central Verdict
The GameSir G7 Pro is a fantastic controller, especially for just $80. You're getting an excellent core gaming experience bolstered by more features than you can shake a stick at, and wireless connectivity with ALMOST everything — but Xbox isn't included, and getting that feature will likely require a new, more expensive version of this controller down the line.
Reasons to buy
    Comfortable and ergonomic design, with swappable faceplates
    Packed with features, including TMR thumbsticks, Hall Effect triggers, remappable buttons, a gyroscope, and more
    Tri-mode connectivity makes it incredibly versatile across Xbox, PC, and mobile devices
Reasons to avoid
    STILL wired-only with Xbox (and wireless support will require a new, separate version)
    Mushy D-Pad
GameSir has become one of my top companies for getting high-quality and high-value gaming controllers, so much so that I made sure to take some time to visit GameSir's booth during CES 2025.
Since I discovered GameSir, my biggest wish was for the company to make a wireless Xbox controller, and it seemed my desire had been granted; during that CES visit, I went hands-on with an early version of the GameSir G7 Pro.
Teasers appeared to confirm what I had been led to believe — the G7 Pro was wireless across all platforms, including Xbox. Once the controller was actually on the verge of release, though, it was revealed that Xbox players have once again been snubbed (most likely because of Microsoft's weird rules with Xbox Wireless, not necessarily because of GameSir).
My disappointment was immeasurable, but I still wanted to test the G7 Pro. I found that this is easily one of the best controllers you can buy right now, especially if you want to spend less than $100... but you'll still need a wire on Xbox. Fortunately, GameSir told me that could change in the future.
So much value packed into a single controller
The transparent shell under the faceplate potentially allows for some really fun designs. (Image credit: Windows Central | Zachary Boddy)
When I reviewed the GameSir G7 SE, I was impressed by the value the modest wired controller provided. The G7 Pro takes that foundation and packs in a whole lot more (plus wireless connectivity) without breaking the $100 barrier.
You get a sturdy plastic construction with proper rubberized grips, a removeable faceplate (with a transparent shell underneath) and swappable D-Pad, quad rumble motors, a total of four additional remappable buttons, optical micro-switch face buttons, a charging stand included in the box, and tri-mode connectivity between 2.4GHz wireless (Windows PC), Bluetooth (mobile devices), and wired (Xbox and PC).
The G7 Pro also uses GameSir's more advanced Tunneling Magnetoresistance (TMR) thumbsticks for even greater durability and precision (and a better feel), and uses classic Hall Effect tech for the analog triggers — which themselves have built-in micro-switch trigger stops.
There's even a gyroscope that works with Windows PC, and GameSir's already-great app on Xbox and PC got a major upgrade with new features and options. That's a lot of controller for $80, and the G7 Pro really does feel awesome in the hand.
I won't go so far as to say this controller is perfect. The analog triggers are a little shallow for my tastes. I wish the rear remappable buttons were textured, the thumbsticks aren't swappable, and the D-Pad is mushy, no matter which version you use (there's a total of three D-Pad types included in the box).
I wish the charging stand used magnets to keep the G7 Pro in place while charging, and while there's a very convenient garage for storing the wireless receiver in the stand, I also wish the stand itself could act as the receiver for a more streamlined solution.
The G7 Pro is flat out better in some ways than the Razer Wolverine V3 Pro, which costs over twice as much.
Those are minor complaints, though, and the GameSir G7 Pro is flat out better in some ways than our favorite Razer Wolverine V3 Pro (which I helped review). That controller costs more than twice as much, but doesn't include a charging stand, Bluetooth support, or more advanced TMR sticks.
Of course, the Wolverine V3 Pro's controls are higher quality overall, you get swappable thumbsticks and an included carrying case, and — most importantly — you get Xbox Wireless support.
Xbox still needs a wire, but a new version is coming
Love the transparent triggers and buttons, hate the weird protrusion for the cable that you need to use with Xbox. (Image credit: Windows Central | Zachary Boddy)
I've really been enjoying using the GameSir G7 Pro. Honestly, I prefer its ergonomics over the far more premium Razer Wolverine V3 Pro, and its performance is nearly as good across the board.
GameSir knows how to make a great controller, and the G7 Pro is certainly the best it has done so far. I simply can't get over the fact that we've gotten so close to an actual wireless Xbox controller from GameSir, only to fall short right at the finish line.
I'll be going back to the Wolverine V3 Pro after this review, because I have a child and a cat who like to forget there's a wire connected to my Xbox. The GameSir G7 Pro is very nearly the better controller in my eyes (and it costs less than half the price), but I'm holding out for a wireless Xbox version.
I'm going back to the Razer Wolverine V3 Pro after this review, but only until the GameSir G7 Pro gets a wireless Xbox version.
I actually asked GameSir why it didn't happen with the G7 Pro, and while I can't share everything I learned, I was told that GameSir is planning to release a new version of the GameSir G7 Pro in the near future that will support Xbox Wireless.
Don't accept this as an official announcement, as details may and often do change as plans develop, but GameSir told me it's targeting around $100 for a special co-branded Xbox edition of the G7 Pro. It's actually happening, but we sadly have to wait a little longer.
GameSir G7 Pro review: My final thoughts
I'm eagerly waiting for the wireless Xbox version, but the G7 Pro is already a great controller right now. (Image credit: Windows Central | Zachary Boddy)
✅You should buy this if ...
  • You want a feature-packed, multi-platform wireless controller.
  • You don't want to spend more than $100 on a pro-grade controller.
  • You mostly game on PC and can also take advantage of Bluetooth.
❌You should not buy this if ...
  • You want a wireless Xbox controller (just wait a little longer).
  • You're really particular about your D-Pads.
I'm eagerly waiting for the GameSir G7 Pro Xbox Edition (or whatever it'll be called), because there's a very good chance it'll be my favorite controller of all time, beating out the Razer Wolverine V3 Pro, the Xbox Wireless Controller, and all the rest.
I hope GameSir also takes the opportunity to refine the wireless Xbox-specific G7 Pro in the same way it refined the standard G7 with later versions. If you need ideas, GameSir, I listed some above for you (wink wink).
While I'm adding to the wishlist, I love how the "Shadow Ember" colorway of the G7 Pro looks — GameSir, please make a purple version of that faceplate. Thanks in advance.
Right now, the GameSir G7 Pro really is a fantastic controller, and it's extremely diverse with three ways to connect to your devices. If you do game on Xbox, though, I personally suggest waiting a little longer for the next G7 Pro.
If PC is where you like to hang, the GameSir G7 Pro is an unbeatable deal for $80, and you can check it out for $79.99 at Amazon or $79.99 at Best Buy (pre-orders begin shipping on Jul. 22, so I assume the controller will become more widely available after that).
Zachary Boddy
Staff Writer
