Prime Day is rolling on through, and for the next few hours, there are tons of deals at Amazon you'll want to consider snagging. For instance, Sony's 43-inch 4K Ultra HD Smart LED TV (X750F) is down to just $379.99 right now, saving you $220 off its regular price. That's the lowest we've ever seen it reach, though you'll need to be an Amazon Prime member to score it on sale.
If you're not yet a member, you can start a free 30-day trial of Prime. That way you won't miss out on this low price, and you'll be able to shop the rest of today's sale too. Our Prime Day hub is a great place to start.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
Binge With Me
Sony 43-Inch 4K Ultra HD Smart LED TV (X750F)
This 4K UHD smart TV features Google Assistant built-in with access to the Google Play Store so you can download apps like Netflix and YouTube straight away.
$379.99 $599.99 $220 off
This Android TV features Alexa compatibility allowing you to voice control it using an Alexa-enabled device like the Echo Dot. It's also equipped with four HDMI ports, three USB ports, and a Composite input. Not only does it feature Google Assistant built-in, but there's also access to the Google Play Store that lets you download apps straight to your TV, including streaming services like Netflix and Hulu. You won't need another external streaming device again.
