Don't let your Steam Deck die during a boss fight over the holidays — grab these Cyber Monday power banks and chargers
Here are some of the best Cyber Monday bargains on power banks and chargers to keep your Steam Deck fully charged while you're on vacation or away from home
I love my Steam Deck, but I'll have to admit, its "12-hour" battery life can drain pretty fast when playing AAA titles that push its specs to the limit without being hooked up to a charger or a power bank.
So, to help you prevent the tragedy of having your Steam Deck power down during a climactic boss fight, we have gathered some of the best chargers and power banks to keep your handheld charged up, whether you're travelling abroad or visiting a friend.
Chargers
Recharge your Steam Deck and other gaming handhelds in a snap with this fast-charging 65W USB-C charger with US, UK, and EU plug adapters to keep them energized, no matter what country you're playing in.
Read moreRead less▼
Save money while charging your Steam Deck and other mobile devices with this affordable and compact charger block with 45W of power delivery.
Read moreRead less▼
Recharge multiple devices at once with this powerhouse charger that features a total power delivery output of 240W, 140W when using a single port, and 100W when using its auxiliary ports.
Read moreRead less▼
This 3-in-1 charger offers two USB-C and one USB-A to recharge your gadgets with 140W power delivery in less than half an hour, whether you're using Steam Deck or a laptop.
Read moreRead less▼
Top up your Steam Deck and two other devices' power supply simultaneously with this 3-in-1 featuring one USB-A port, two USB-C ports, and 100W of power delivery.
Read moreRead less▼
Power Banks
Don't have a charger or a compatible power outlet on hand? Then use Anker's Power Bank to keep your gaming handheld topped with its 65W charging power and 20,000mAh for extended use.
Read moreRead less▼
This is a mighty, 20,000mAh power bank that features a 25.6-inch retractable USB-C cable to plug into your Steam Deck, a display screen to track its power supply, and a USB-C port to charge an additional device with 160W power delivery (split between 100W and 65W output).
Read moreRead less▼
Have your Steam Deck's power supply go from zero to a hundred in less than an hour with the JSAUX's power bank, thanks to its durable design, 65W of fast-charging output, and 20,000mAh.
Read moreRead less▼
Charge your Steam Deck and laptop with 145W fast charge speeds at the same time with the Baseus Laptop Power Bank. This stylish and beefy power bank includes 2 USB-C and USB-A ports, 145W output between two devices (with 100W to a single device), and 20,800mAh to so it can supply power for several days on the road.
Read moreRead less▼
This is a lightweight power bank that will keep your Steam Deck running while being compact enough to keep in your pocket for travel. It features 65W power delivery, 20,000mAh to help it last for days, and multiple USB ports (one USB-A and two USB-C).
Read moreRead less▼
More Cyber Monday Steam Deck Accessory Deals
- Essential Steam Deck Starter Kit on sale
- Best Cyber Monday deals on microSD cards for Steam Deck
- Our top 6 picks for Steam Deck screen protectors on sale
- Best discounted Docking Stations to turn your Steam Deck into a PC
FAQ
What's the difference between power chargers and power banks?
Chargers plug into power outlets to recharge gadgets, whereas power banks have built-in batteries to store electricity to recharge most of those same gadgets.
Power Banks don't require power outlets to recharge a device, so they can be useful in areas where they're not available, like in the wilderness, cities during a power outage, or planes/cars/boats.
Although Power Banks will need recharging as well at some point, it's best to use them only in situations where power chargers can't be used.
What does wattage and mAh mean?
Wattage (W) measures the power output of a device, whereas mAh (milliampere-hours) measures its battery capacity. So, the higher a charger or power bank's wattage is, the faster it will recharge your Steam Deck and other compatible devices.
Also, the more mAh a power bank has, the longer it will last. For example, a power bank with 20,000mAh can last for several days or possibly a week before needing to recharge.
Should I keep my Steam Deck always plugged to a charger or a power bank?
You can safely leave your Steam Deck plugged in while playing, but it's not recommended that you leave it plugged in 24/7 while not in use, as the excess electricity can stress and wear down the gaming handheld's internal batteries over time.
Can these power banks and chargers be used with other devices?
Yes. All these chargers and power banks can be used with multiple devices with USB-C or USB-A connections like laptops, MacBooks, mobile phones, and other gaming handhelds like the ASUS ROG Ally or Lenovo Legion Go.
What is Cyber Monday?
Cyber Monday is a shopping event that happens after Black Friday, where retailers host discounts primarily on electronic goods like video games, video game consoles, PCs, laptops, and various accessories related to them.
Is Cyber Monday better than Black Friday?
It depends on your needs. Cyber Monday is primarily relegated to digital stores and focuses heavily on discounting electronic products (some of which are cheaper than seen on Black Friday).
However, Black Friday is more widespread as the event applies discounts on all kinds of products like toys, clothes, and even food, not just tech goods. Plus, retailers these days don't wait for Black Friday and often start hosting deals throughout November, instead of only a few days near Cyber Monday.
If you're looking for a discount on electronic goods, Cyber Monday is for you, whereas Black Friday is more catered to a wider range of products.
When is Cyber Monday 2025?
Cyber Monday has officially begun today, on December 1, 2025. There will be plenty of electronic goods on sale for the day, and some deals may persist days after Cyber Monday is over.
More Cyber Monday 2025 — quick links
- All our TOP recommended Cyber Monday deals: Just the best
- Mini PC deals: up to 47% off tiny PCs
- GPU deals: early price drops on NVIDIA RTX before they go up
- Microsoft Surface deals: save up to $500 on premium PCs
- Xbox accessories: best deals on gadgets for your Xbox Series X|S and PC
- Gaming laptop deals: the best laptops for the best price
- Xbox controllers: our top picks for best controller deals
- ANC headphones: great Cyber Monday deals on the best ANC headphones
Even more Cyber Monday deals: - Dell deals: 13 deals from Dell.com that you shouldn't miss
- Best Buy: 34 hottest discounts on laptops, monitors, gaming, and more
- Walmart: 7 top laptop deals you shouldn't miss
- Samsung monitors: the best Samsung display deals we've found
- Retro gaming: handhelds, arcade machines, old school consoles, and more
- Gamer merch: Blizzard’s Warcraft, Overwatch, and Diablo IV collectibles
- Game keys: 10 PC game codes are even cheaper at Loaded (formerly CDKeys)
- Accessories: Even more PC accessories starting at $17
