Best Xbox One Wireless Controller Replacement Parts Windows Central 2021
Microsoft's Xbox One wireless controller is essential for any gaming setup but isn't guaranteed to last forever. If your gamepad fails and is out of warranty, third-party replacement parts present a fix on the cheap. These leading replacement parts are here to help with any repair.
- Bumper fixer: Xbox Bumpers and Triggers Replacement
- Stick switch: eJiasu Xbox Thumbstick Replacements
- Covered up: MoKo Battery Cover Door Replacement
- Turn up the volume: Xbox Controller 3.5mm Headphone Jack Replacement
- New look: eXtremeRate Xbox Controller Soft Touch Faceplate
- Know your ABCs: Perfect PCA Xbox ABXY Button Replacements
- Tiny buttons: Perfect PCA Menu and View button replacements
- Charged and ready: Microsoft Xbox One USB Charging Cable
- Full replacement: Microsoft Xbox One Controller
Xbox One controller bumpers have gained a reputation for their fragile construction, faltering over long-term use. This dual-pack of bumpers and triggers is a cheap fix for a common issue.
This duo of thumbsticks will amend long-term wear or sudden drops. Dual thumbsticks and sensor modules are included in various colors, with tools to open your gamepad. While replacing sticks is easy, switching the sensors requires a quick solder.
If you've lost your Xbox One controller's rear battery door, MoKo offers a perfect third-party replacement. This 4-pack is available in a sleek black or white finish.
Swapping out a damaged headphone port is simple on any Xbox controller. A 3.5mm jack is cheap and fast to install, ideal if you want to avoid a full replacement.
These faceplates pack an alluring in-hand feel with their soft-touch finish. And in over a dozen colors, they're ideal for both repairs and customization. While designed for modern third-generation controllers, older shells are also available.
Switch out your ABXY buttons with the range of replacements mirroring Microsoft's stock parts. You'll find colors suited for all occasions, and it caters to special edition designs too.
For controllers packing Microsoft's Play & Charge kit, this Micro USB cable is a perfect pairing. The original 2.7-meter cable is available standalone, with a light to indicate charging status.
If your Xbox One controller is nearing its end, don't overlook a full replacement. Official entry-level controllers start at $50 via Microsoft.
With a growing ecosystem of third-party parts, fixing up your Xbox One controller is easier than ever. While some advanced repairs require technical expertise, solutions to common issues are often a short guide away. However, for a hassle-free fresh start, a new Xbox One controller might be best for some.
The capture cards Xbox streamers need to know about
Looking to improve the quality of your gaming videos or streams? The Xbox One does an OK job with built in software, but to kick it up a few gears you need a good capture card.
Expand your Xbox storage with one of these spectacular SSDs
Chances are you're going to run out of space on your Xbox One. These five leading SSDs pull the best out of your Xbox One.
How to go sim racing on your Xbox without breaking the bank
Want to take your Xbox One racing experience up a notch (or two) without spending your life savings? Here's how to build a good racing rig on a tighter budget.
