Meross is offering its MSG100 Smart Wi-Fi app-controlled garage door opener for just $38.99 at Amazon. To get the discount, you need to clip the $5 on-page coupon and enter code FREVFBCH during checkout. This device regularly sells for $55 and you're getting it for one of its best prices to date with the combined coupons.
Open up!
Meross MSG100 Smart Wi-Fi app-controlled garage door opener
Turn your dumb garage door opener into a smart one with this device.
$38.99 $54.99 $16 off
With coupon: FREVFBCH
The Meross MSG100 is a smart garage door opener that was originally crowdfunded back in November 2018 on Indiegogo. It adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub or anything like that. It's really easy to set up, too.
Once up and running, it works with Amazon Alexa or Google Assistant for voice control and you can use the Meross app to turn your phone into a garage door remote control. You can get notifications that let you know whether the door is opened or closed, overnight notifications that help remind you to close it, and more. It comes with strong adhesive that you use to install it, making the entire set up process quick and painless. Users give it 4.2 stars based on over 200 reviews.
